Does anyone know of a website that allows you to chart your course? The more features the better, but I'm specifically looking for something where i can map the roads I want, and hopefully, be able to print the map with a highlighted course. Mileage would be great, too. I'm pretty sure Mapquest can't do what I want because I'm not looking for the shortest route. Any ideas?
try: http://www.gmap-pedometer.com/
It uses maps.google.com base and you can zoom into detailed parts of a map, but more importantly you can select points a long the way and save your path. Even as a web link.
Good luck.
Microsoft Streets and Trips does what you want, and more.... [thumbsup]
http://www.grouprider.com/
This is the one I use.
It uses google maps which is pretty cool because you can switch back and forth between the map and satellite views.
The only thing to watch out for is sometimes it lets your route double back on itself and throws your mileage off, it does seem to work better if you actually try to click on the correct side of the highway for the direction your traveling if that makes sense.
