I recently installed heated grips on the SV. I had to cut the loom around the ignition wiring to tie in the power supply. I taped everything up using electrical tape, but the wiring is still somewhat exposed to the elements. I ride in the rain fairly often and don't want the wiring to short-out.
I can't really use regular heat-shrink tubing because of where the power wire splits off and the terminals under the tape. Is there anything out there in a sheet (or similar) that I can wrap around everything, then use a heat gun to bond it in place? Any other options?
