Was trying to replace the fuel filter under the tank, and quickly realized I could not figure out how to make the silver metal 'clamps" on the fuel lines open up. What am I missing here? They don't appear to be any type of clamp I am familar with..
Whats the trick to getting these to open?
I use a pair of wire cutters (gently) to pry them open.
or you could take this oportunity to just cut the lines and install a pair of Quick Disconnects
I use a scribe and pry up in the little hole at the end of the clip clamp. When you pry up it unlocks the little teeth. When you put them back on use needle nose pliers 90 degree ones preferrably.
