Here is the list I have put together to get a carbed Ducati to run smoother at low revs. In the rough order that I would do them.... some have a very small effect, some a larger effect.... some cheap or free, some crazy expensive....
Any thoughts or additions?
Lower gearing.
Balance carbs.
Dynojet kit for standard carbs.
New chain & sprockets.
Light weight chain.
New clutch parts, basket, centre & friction plates.
"Quiet clutch mods" which stop the clutch pack from slamming back & forth.
FCR 39 carbs.
Ignitech ignition, or any good ignition with adjustable maps.
Ignition timing can be adjusted to give better low rev running.
New coils, leads, plug caps, & spark plugs.
Keep standard weight flywheel or increase weight.
Cam timing, adjustable cam drive gears to set perfectly in time with each other or advanced for low rev running.
Twin plug heads.
Engine balancing internally.
Lower gearing.
Balance carbs.
Light weight chain.
FCR 39 carbs.
Twin plug heads.
