1 - 10 of 10 Posts
basically, just this: How to access the throttle body balancing screw!!?
Bike is a 2005 M1000S. The TB balancing screw is tucked in the front center of the TB's. I can see it....but it is angled toward the ground. I have every length of screwdriver. But it seems that there is no clear path to access the screw! Please, anybody have a magic technique for getting access to this for a person who is not double jointed and has chubby arms?
In some cases you may have to remove the airbox. In my case (900ie,) that's what I do.
I've heard of some who claim it can be reached using a flexible shaft,
as used for drills, and turning by hand/spanner etc. I've never tried that.
Either way, it's a pain to get to.
Are yours similar to these?
yes, earlier injectors, you would have brown Pico's.
6. is the adjustment.
226744
That looks very familiar, yes. If not exact, it is very similar to that. I will try taking the airbox off then, thanks. Sure wish it has been set up like the throttle stop screw on some bikes. Sure would have made balancing the TB's a lot easier. Thanks again.
On my S4RS it’s easy to get to it when I remove the airbox, but If I use an angled socket elbow I can navigate it under the frame.
thanks. I think I will try using a socket before taking off the airbox. Do you happen to know the socket size? Looks maybe 8mm?? I found i can actually angle a long screwdriver to the screw. But then that is all I can do, because I am almost laying down to see what i am doing:(
If you remove the oil cooler and from the right of the bike open the throttle a little you should be able to get in there with a long screwdriver. Thats how id did it on my M900Sie
Discussion Starter · #10 ·
As I was checking valves I realized this was the path of least resistance:) Thanks all.
1 - 10 of 10 Posts
