I know what the manual says and what the dealer says. But how much oil do you put in your duc. I have a s2r1000 06 and need to change my oil the dealer said I should put in 4 quarts others have said 3.2 - 3.5. Has anyone changed the oil on a s2r1000 and how much oil have you put into the bike?
Thanks,
-ghost
Never did an S2R1K. My 900 takes about 3.25 qts.
howie said:
Put in three, run it and top off.
this is really the best way to do it as it could be different for you depending on how much you drained out, how long you waited after getting the engine hot so the oil drained down, etc etc... you should be a bit over 3 every time, I'd venture to say 4 is way too much
