Just curious how many miles past 6k,12k,18k etc have you went w/o adjusting/checking the valves?
7000 miles for 6k (done by dealer), everything was within spec. 13,500 for 12K, done myself. Closers were within spec, openers were within spec on exhaust, needed a little sanding on the intakes. I plan to do the 18K at 18K to get everything back on track, and I'll be due new rubber bands by then as well.
David B.
you know my story ;D
jsut dont' forget to check the cam timing. ::)
also, the openers weren't too far out of spec, but the closers were generally a full .010 mm out.
