Termignoni's for '01 M900Sie (just got it)? i'm not experienced with mechanical work. Need any special tools? any special instructions? thanks a lot. Any detailed instructions would be greatly appreciated..
Low pipes, I assume. There are two bolts per can. You don't need anything more than very basic tools. It's really straightforward.
One bolt is right by the passenger peg of the rearset. The other holds the clamp that holds the stock pipe into the header. I've circled them below. Undo both the bolts. The stock exhausts can sometimes be lodged in there pretty well. Keep wiggling them back and forth until they come out. I've even had to take a rubber mallet to a particularly stubborn one. Don't worry, you're not going to break anything. Slip on your slip-ons and do the process in reverse. Voila!
If you get stuck halfway through, and post up here. People will walk you through it.
When you're done, light 'em up, sit back and listen to the sweet, sweet rumble. [thumbsup]
