I've heard lots of discussion on peoples instrument panel fogging up. Well, mine has before, and cleared up after a few hours riding. However, Mine fogged up real bad a week and half ago, and now there is a fogged stain on the inside! At night it's no problem with the cluster lit up. But in the daytime, it's almost tough to see the readings. Should I look into this being replaced under warranty? Also, how can I prevent this? I am assuming the front dials aren't tight enough of a seal. Is there a product you could apply to seal off the openings?
I have a fogging problem also. My cluster is being replaced under warranty, even though I don't have any mechanical problems with it yet. Considering it's all electronic in there, unlike an "old fashioned" gear based system, I'm a little paranoid the moisture will short something out.
Ride real fast, it will dry out. Or move to San Diego.
Mine did it lso and was replaced under warranty.
After 4,000 miles I am back to "0".
buy a japanese bike..that will make it go away! :-X
