The bike should have an idle at 12 - 12K RPM. If your idle speed mysteriosly got significantly lower there is something wrong that needs to be corrected before looking at idle speed. How is the bike running other than a low idle? Any other info?
should idle around 1000-1200rpm. there are brass air bleed adjuster screws on each throttle body...WAIT...BEFORE YOU TOUCH THEM MARK THEIR ORIGINAL SETTING WITH A SHARPY OR DAB OF PAINT!!
They could be covered by stubborn plastic caps, that you will destroy trying to remove them. Adjust each a quarter turn at a time...left side then right side..etc.., until you get the desired rpm.....only after the engine is up to operating temperature should you adjust these bleeds.
if you have any questions you can PM me.
RBx
