1 - 9 of 9 Posts
I have a 2003 Monster 800 SIE that I recently bought. Does anyone know of a way to loosen the clutch. I do a lot of riding in the city, and by the end of the day my hand is sore as hell! Hopefully someone knows of something. I heard of a clutch slave or something, but I am not quite sure what that is. HELP MY POOR HAND
get an aftermarket clutch slave cylinder.
it's on the left side of the bike by the engine cover, just in front of the front sprocket.
follow your clutch line down from the handlebars and you'll find it.
We carry a few different brands.. most around $200. They will reduce lever pull by up to 25% they claim. We have installed many and they do make a difference, also consider some CRG levers as they will bring the lever in a bit closer to the bars and also help ease the fatigue....
If you wish to take the cover off, you could always pull a couple of the springs. Did that to mine with no issue, but I also install a new Barnett at the same time
The soreness goes away after a week or two of riding, once your hand muscles learn to quit complaining and grow up.
use a wrench [cheeky]
check out www.evoluzione.net. they have the clutch slave cylinder. 20% reduction in force. makes a difference. i have one on mine.
look on e bay i have just purchased one with 35 % less effort to pull in , and yes its better. the company is in germany , the quaility very good and different anodised colors to suit your bike, and less than 200 hundred of your green backs , just put in " slave cylinder in bike section, good hunting 8)
+1 for spring removal. i did it yesterday, the actual friction zone seems to have moved out farther from the grip a bit, but it's a lot easier to pull. I'll probably get the stainless springs (a little stiffer than stock) and cancel out some of the difference, but it's quite noticable and only takes about five minutes.
1 - 9 of 9 Posts
