1 - 9 of 9 Posts
I’m awaiting the package to be delivered and need help please on the install as I want to try DIY.
Anyone with pics, info to assist me will be appreciated along with what settings do you go with?
And where did you have it hidden?
Thanks in advance
Hi
I have had an IRC shifter and auto blip system for my 1200S on order for 3 weeks but it still hasn’t come in. When it does, I’d be happy to provide info from my setup. I’ve installed several shifter systems that operate like this one does and it’s not very difficult. Supposedly this one has all the plugs to fit OEM wiring which will make it easier vs having to cut into your wiring.
The key is to properly set the point at which the system will trigger the interruption of the coils when your foot presses on the shifter. If you purchased the blipper as well, getting the setting right that will signal the system to blip your throttle when your begin to downshift is also critical but not difficult.
I’m curious where you purchased yours from and if you’ve received it yet.
Hey, I ordered mine from HPS in the UK as stock just came in last Friday as many sales supposedly.
As a shout out to them I was impressed they rang me about order left in cart. TBH shipping was too much then what I wanted to pay shipped to Australia.
He gave me a great deal all up so I couldn’t resist. About $1000 altogether where best on eBay was $1200 plus tax 10%
I have done power commanders on Hondas before and this is my 1st Ducati hence new altogether and no Hayes booklet to guide me on electronics either.
So scared of plugging into wrong things and Ducati worth x 2 Honda more expensive to fix..
Pics and guides a great help and mine is meant to be shipped in next 48hrs express to me so this time next week I hope to have it to install.
HPS stated the settings are pretty good from the get go so no real reason to play about unless your really light or heavy on shifter. But call them or IRC as both happy to help. Spoke with him-Giles for about 30min which I see as great service calling the other side of the world.
Where did you get yours? As I’m also trying to guess if it will fit under the seat..
I have just installed a IRC blipper on my M1200R.
The installation is quite simple actually, but as mentioned above the installation manual are confusing and not easy to understand.
First check that you have the correct cable harness (mine was first delivered with wrong type). If the connectors fit the coil you have the right one.
There is a plug located and fastened just behind the steering stem at tank side behind a rubber cover (the biggest plug in the kit)
The gear switch plug was located in the battery box (the installation said follow a cable under the rear cylinder)
Take a good measurement of the gear leveler position in order to get it back to the same position.
I have used the default values recommendation in the manual, This has been a nightmare. In the middle of a corner it suddenly starts blipping (cutting ignition). In the end of every blip there’s a small boost. Be very careful at first test ride.
This is as far as I have come with my experience. If I can’t get it to work as expected, I think maybe I will remove the hole thing. (First after a few more tests)
If someone has some setup values that works I would be grateful.
Discussion Starter #6
Question for the Blipper, did you have to buy any “EXTRA” parts for the install? As looking to install it in next 2 weeks. How’s it going? What numbers do you have for the box?
Vorgehen:Beide Buttons des drcken。Es erscheinen修飾了Buchstaben im Display,將einer oder zwei纏繞在一起。恩· 埃因斯泰隆 · 祖恩恩( Um eine Einstellung zuändern),鈕扣德呂肯(Buttondrücken)。Dann kurz unten oder kurz obendrücken,um einen Wert zuerhöhenoder zu senken。Falls fertig,Lange den oberen Buttondrücken,Einstellung wird gespeichert。
奧斯汀(Aussteigen):貝德·巴頓(Beide Buttons)Drücken,朗格·沃滕·奧登(Zündungaus)。
在Klammern中,jeweils der angezeigte參數。
升檔終止時間(t):60ms
降檔rpm(rL):03(北Werten darunter gibt es bei mir irgendwann im Betrieb eine Engine-Warnung)
降檔時間(SL):65毫秒
升檔預加載(L):12(默認IST 14)
實際載荷(S)。Dient nicht zum Einstellen。Bzw的Echtzeitdurchgeführtwerden的HierkönnenLoad-Messungen。um zuprüfen,北welchem Druck geschaltet wird。
降檔正時8000rpm(tS):63ms
降檔預載(LS):13(默認IST 14)
推/拉(CE)。E提拉,C推推Referezzum Upshift。Wichtig beim Umschalten auf Rennschema。師範學院Schaltschema:C.
開路/閉路(OC):C
im 3. auf 2. und 2. auf 1. Gang(1A):01,默認值00的閃爍時間增加
平滑度(rr):12
固件(tt):10,nichtsändern
224515
Discussion Starter #8
Thank you, I put the settings in and will give it a go tomorrow
1 - 9 of 9 Posts
