Hi all . . .
I ride a Monster 620ie and after playing around with the bike this afternoon I noticed that my rear light does not work !!
It works when I apply the brakes, but does not turn on when ignition is on !!
Does anyone know what the usual fault is ???
All I can think of is that something has been dislodged.
I changed the spark plugs to Iridiums, so in lifting the tank and removing the seat . . . something has gone loose !!
thanks in advance . . .
Check the fuses first, then check the filaments in the globe if the fuses are ok. Sometimes on filament will blow.
howley ! . . .thanks mate !
I should have checked that first !!
damn filament is gone ! hahahahah
And I was ready to start pulling wires tonight ! [laugh]
I thought something has dislodged !
I lifted the front tyre again this afternoon and put Iridium spark plugs in. I thought removing the seat probably loosen something.
Front tyre was lifted because I was in the centre lane.
To my right was a worked GTHO.
To my left was a Monaro GTS.
What else would you guys have done in that situation if they both bleeped their throttle and you had loud Termignonis . . . .
. . . sorry, just had to share the moment with you guys. ;D
