So I'm installing my R&G frame sliders last night. Bike is on center stand, have a hydraulic floor jack (with wood buffer) supporting the motor. I take the bolt off the motor mounting bolt and start tapping it through. I insert the slider bolt through the frame and start working it through as the stock bolt exits. All is going smooth. Just as the frame bolt is about to exit the bike on the port side, it binds a bit. I can move it around prettty easy, but can't get it out (without hammering it, which I don't want to do). Seems almost like the motor is slipping forward just a bit relative to the frame to bind the bolt. I was afraid to hammer it all the way out, in case the motor slipped more and I couldn't get the slider bolt all the way across, and I didn't want to strip the threads on the end of the bolt either.
Anyone have this problem? Am I being a pu$$? Should I just give it some elbow grease and get it out? Anyone? Bueller?
I'm really not excited about having to go to my dealer to get something as simple as this done.
I thought about strapping the motor up to the frame using tie downs. Anyone do this?
