Hola from San Juan, PR
Just bought a 06' S2R 800 in mint condition (only 920 miles on it)
and three days after... I can't start it because the immobiliser got activated... I don't have the Red Key or the Code Card. What to do??? can I bypass the immobiliser or do I have to go through the expensive way of fixing the problem?
Any guess?
If the black key worked when you bought it there is no reason why it should not continue to work. Does the dash indicate that it is imobilised?
You can have the imobiliser function disabled, this would involve sending the ECU to the CONUS
