I had posted about a week ago about my spark plug woes and found not one owner with similiar problems.
I am attempting to replace my spark plugs myself while I'm replacing my leaking battery.
I bought the replacement plugs from Pro-Italia ($18.95 each) only to get home and realize the terminal was solid, the cap did NOT remove. (AS NEEDED)
I then returned those to Pro-Italia, as they did not have the proper ones.
Then I went on Sparkplug.com and ordered the proper NGK plug (DCPR9EVX) ($6.40 each)
Once again, upon arrival the terminal was solid the cap did NOT remove. So I called Sparkplug.com and explained my frustration.
They were very helpfull and sent me out what they said was the proper plug, (DPR9EIX-9). Same price.
So they arrived today and sure enough the terminal is exposed as needed but the plug uses a 18mm socket instead of a 5/8 spark plug socket.
The 18mm socket will not fit down the spark plug shaft....................
Can you say......I'M GETTING REALLY REALLY FRUSTRATED!!!
Do any of you S4 owners have any ideas, or have you all just had the dealer chang your plugs.....(or have they?)
I JUST WANT TO PUT MY BIKE BACK TOGETHER WITH THE RIGHT SON OF A B***H SPARK PLUGS, MADE EXCLUSIVLY FOR YOUR ONE AND ONLY IN THE ENTIRE UNIVERSE DUCATI MOTORCYCLE......SO BEND OVER AND PAY $18.95 A PIECE
