Hi all, I noticed last week my fast idle lever (cold start lever / switch) wasn't working on my 2006 S2R Dark. On careful inspection I found that the screw that the lever on the handlebars pulls a cable which turns a cam on the throttle body which pushes against the throttle cam turning the throttle a little. Unfortunately, it looks like the screw that would screw into the fast idle cam is missing so there is nothing to push against the throttle cam.
I checked the S2R service manual and the parts catalog and neither break out the cams on the throttle body. (Why?) So I apologize if I am calling things the wrong name here. Unfortunately, this also means the dealer is not able to find me this part.
So, I pulled the cam off and tried different screws. It looks like it might be a M5 x 0.8 but that screw doesn't fit. It also looks like the threads might be a little stripped but it's hard to tell.
So, does anyone know what this screw is? Is it possible to get one or do I need to make one?
This link goes to some pictures I took of the cam the screw screws into and some pictures of the screw near it that adjusts the idle (I think?). I would assume these are similar since they do similar things. The throttle one is definitely M5 x 0.8 but it doesn't fit.
Pictures: http://www.flickr.com/photos/vonnieda/sets/72157623511431407/
Any ideas?
Thanks,
Jason
Any ideas?
Thanks,
Jason
