I'm in the middle of fitting Sil high ovals to my M800 but can't figure out what to do with the mounting bracket thing welded to the s-pipes. I have the stock rearsets and it kinda sorta lines up with one of the bolt holes where the CF heelguards were attached on the inside of the rearset. But I can't convince myself it's a good idea to hard bolt the pipe to the rearset, even if the latter is rubber isolated all the way around. What did the rest of you Sil owners do?
