Help me out here, guys!
I'm trying to map out an AGGRESSIVE weight reduction strategy for my S4, with the following value judgements:
Highest value: Rotating, unsprung weight (because of the dramatic effect on suspension action, handling, responsivesness, and acceleration)
2nd highest value: Non-rotating unsprung weight (because of dramatic effect on suspension action & therefore handling, and acceleration)
3rd highest value: Static weight that is physically HIGH on the bike and/ or very OUTBOARD of the centerline of the bike (because of the dramatic effect on handling, and acceleration)
4th highest value: Static weight that is LOW on the bike (smaller impact on handling, but noticeable effect on acceleration)
NOTE!!! ALL above "values" affected by the obvious: cost effectivess (i.e. bang for buck, and availability of "deals"), so I have NOT proceeded in the theoretically best order. For example, my S4 was on the showfloor barnd new this past January with some of the changes below already added to it.
My current wish list, about 50% achieved, shows a REALISTIC target of over 48 lbs, and is as follows:
The numbers shown under each represent:
Stock weight in lbs
New weight in lbs
Net change in lbs
Cumulative change in lbs
Termignoni high mount CF mufflers vs stock system
22.8 8.5 -14.3 -14.3
Airbox: remove sound shroud & cut cover
2.1 0.1 -1.9 -16.2
Billet license plate holder
? ? 0.0 -16.2
CF belt covers (stock on S4)
0.5 0.5 0.0 -16.2
CF side covers
0.6 0.4 -0.2 -16.4
CF rear hugger (stock on S4)
0.9 0.9 0.0 -16.4
CF clutch cover
2.5 1.1 -1.4 -17.8
Alloy rear sprocket
1.7 0.8 -1.0 -18.8
Nichols flywheel
4.1 0.6 -3.6 -22.3
STM billet 48T clutch basket, pressure plate, disk set
6.9 4.6 -2.3 -24.7
ADD center stand
0.0 5.7 5.7 -19.0
(don't give me grief on this. I WANT one!)
All the above already done, either via initial purchase with the new S4 2.5 months ago, or as add-ons since then.
Still planning to do at some point:
Lightweight Moto-Master rear brake rotor (on order)
1.9 0.8 -1.2 -20.1
Replace Yuasa YT12B-BS with Yuasa YTZ7-S
7.6 4.6 -3.0 -23.1
Rearsets assemblies (rider AND passenger caapbility)
? ? 0.0 -23.1
Triple clamp assembly - Cycle Cat billet
10.0 ? ? -23.1
Adjustable clip-ons - CycleCat
? ? 0.0 -23.1
Ducati Corsa Carbon Fiber swingarm caps
1.0 0.5 -0.5 -23.6
Galfer lightweight "wave" front brake rotors
7.3 4.9 -2.4 -26.0
Wheels - change to (Marvic Piuma?) cast magnesium
27.2 18.5 -8.7 -34.7
Change from 525 to 520 chain (2 sprockets & chain)
6.6 4.5 -2.1 -36.8
Change brake rotor bolts - front & rear - to Titanium
0.4 0.2 -0.2 -37.0
Gas cap - Pantera Billet
0.8 0.1 -0.7 -37.7
Change side stand to lt wt SBK
2.0 1.1 -0.9 -38.6
Headlight assembly - change to dual from Spareshack or ??
2.8 2.2 -0.6 -39.1
Carbon fiber fuel tank -3.0 -42.1
CF tail guard
? ? 0.0 -42.1
CF handlebars
? ? 0.0 -42.1
CF fairing (also smaller than the stock S4 fairing?)
? ? 0.0 -42.1
? ? 0.0 -42.1
? ? 0.0 -42.1
(cumulative weight reduction is actually 47.8 lb, but the gain of 5.7 lb for the center stand drops it to 42.1)
Several questions for anyone willing to help by responding:
- Any errors in above weights?
- Can you provide any weights marked "?" ? (BIG help!!)
- Do you have BETTER candidates for individual items (eg. better front rotor ideas)?
- Any additional items I should add to the potential list?
- Know of any deals on any of these items (new or used)?
- Also anyone know the REAL weight of a STOCK S4?
I'm cursed because I am an engineer by background, and I HAVE to see just how low I can get that S4's weight before I run out of money and sanity. Help a fellow Ducati addict out . . .
I LOVE the way this bike feels already, and can only imagine how much better it will be with MORE weight reduction!!
Jim G
[email protected]
Stock weight in lbs
New weight in lbs
Net change in lbs
2.1 0.1 -1.9 -16.2
? ? 0.0 -16.2
0.5 0.5 0.0 -16.2
CF side covers
0.6 0.4 -0.2 -16.4
0.9 0.9 0.0 -16.4
CF clutch cover
2.5 1.1 -1.4 -17.8
Alloy rear sprocket
1.7 0.8 -1.0 -18.8
Nichols flywheel
4.1 0.6 -3.6 -22.3
6.9 4.6 -2.3 -24.7
ADD center stand
0.0 5.7 5.7 -19.0
1.9 0.8 -1.2 -20.1
7.6 4.6 -3.0 -23.1
? ? 0.0 -23.1
10.0 ? ? -23.1
? ? 0.0 -23.1
1.0 0.5 -0.5 -23.6
7.3 4.9 -2.4 -26.0
6.6 4.5 -2.1 -36.8
0.4 0.2 -0.2 -37.0
0.8 0.1 -0.7 -37.7
2.0 1.1 -0.9 -38.6
2.8 2.2 -0.6 -39.1
CF tail guard
? ? 0.0 -42.1
CF handlebars
? ? 0.0 -42.1
? ? 0.0 -42.1
? ? 0.0 -42.1
? ? 0.0 -42.1
Jim G
[email protected]
