Installed rear turnsignals I got from motowheels, but they keep blowing the fuse. Does anyone know why and what I can do? Thanks.
Scotty
No. There not LED there regular bulbs. Do I still need to install one.
Thanks.
wires are backwards... i've done it a few times and now i always check. the all black one on the turn signal is probably the + and the black with white stripe is the -. Easy to check... ohm each wire to the metal post of the turn signal.
Thanks chris gonna try that....By the way love the spark plug wire kit I got from you.
Easy install instructions, and fast shipping. [thumbsup]
Yep. That was it chris, wires backwards.
Thanks for the help.
