I have pointers on some of the problem areas that I corrected. It is far from done but close in the pics here. Not much unshrouding possible at the bowl edge due to the small 88mm cylinder but corrected just the same. This will drop compression a bit but that can be gained back by setting the squish (moving piston closer to head).
