1 - 12 of 12 Posts
Does anyone have a pic of their 821/1200 headlight wiring harness that shows the order and color of the wires? I am trying to understand the order of the wires in the connector.
For context, I am wiring a headlight designed for a '16 821/1200 to my 796. I don't know how the wiring harness is wired for the 821. Is it in the order of the diagram? Reversed? I don't know how else to figure out the wires on the new light, open to suggestions! Thanks all
For starters, the 821; I'm only seeing a three not four wire connector...and on the 821...starting from the end closer to the center of the bulb is ground...plugging the other two into a positive lead will tell you the rest
Wild - your 821 is a 2015?
Discussion Starter #9
Thank you so so much.
Just to confirm - if looking at the back of the headlight, the black/ground wire is the one on the far right?
1 - 12 of 12 Posts
