Chris,
I can't bump up displacement. I want to be competitive in lightweight twins against SV's. That will be tough, though a lot of mods are allowed. However, ultimately that will be dependent on as much as I can get out of the motor plus lots of suspension work, corner speed and balls. I want to keep the work on the motor invisible to run in a lower class for fun and need to keep the changes invisible without going too far. I need to keep the stock parts on the outside. I was thinking bigger valves, port and polish, lighter flywheel and have my tuner do a little cam work. I want to go between classes without doing anymore questionable engine work than anyone else. I did look @ that Aussie sight and was really impressed. Do you have access to bigger valves for a carburated 750?
