EFI for V twin Motorcycles
http://www.performancefi.com/main/index.php
http://www.pegasusfi.com/
Wikipedia:
Not just a replacement ECU but an ENTIRE engine management system for any V-Twin Engine!!! Kit includes everything you need for a turn-key system; throttle body, fuel injectors, ECU, sensors, fuel pump, ignition coils, wiring harness, and all mounting brackets!
What can electronic engine management do for you? By combining both electronic fuel injection and ignition control into a single package, you can expect: much more power, better fuel economy, crisper throttle response, easier starts, and complete adjustability.
Wikipedia:
Finally-a fuel injection system that really works! BDL® introduces the PFI-V Electronic Fuel Injection and Ignition Control System!Generally, any two-cylinder motorcycle engine with its two cylinders at an equidistant opposite angles from the center rotation of the crankshaft is referred to as a V-twin. The Ducati V-twin is unique in that it is a 90 degree "V" leading many to refer to it as an "L-Twin" engine instead. Either usage is correct since a "V-twin" engine is not designated by a specific angle.
