1 - 18 of 18 Posts
**** it's been over a year, finally got my account restored after that big change and I lost access. Recent mods include New Rage Cycles integrated tail, replacing my Ducati Monster Tailchop one (super nice, love it and so much more room for activities!), Rizoma Next tanks replacing those fugly pisscups, turn signals, CNC Racing flange, Oberon clutch slave with a fancy new red cable (hawt!, at LEAST +0.002 hp added), ASV levers along with some carbon fiber goodness. Next up for the winter includes a **** ton of stuff from Ducabike (Pilot rearsets, that nifty handlebar switch that looks like a MotoGP bike, and a damper, oil bath cover with new pressure plate, etc.), more carbon fiber, and some new wheels (gold Oz Racing Gass-RS more than likely). Any plans for winter mods on your beasts?
  • Like
Reactions: donlycan2
Is that a 2013 anniversary eddition? New to the forum I just bought one used a couple months that back.
Hell yeah! #119/200. Just flipped 38k miles, I can't stop riding it. Of the 13 Ducs I've owned, this one is by far the most fun to ride, I can't explain it. It's been very affordable to own too, and hasn't broken down a single time. Love it! Got any plans for yours in regards to mods?
Mine came with termignoni pipes, a bunch if other little aftermarket stuff and the guy had it tuned. I only have a problem starting it. Once it's running it runs like a dream though! First Ducati I've ever owned. It's the 796. It has low miles, can't remember exactly, around 5k?
Sent from my Pixel using Tapatalk
Sometime opening the gas tank makes starting easier. I have to hit the smart button for a second shut off, open gas cap, close then it starts up perfectly.
Sent from my HTC6535LVW using Tapatalk
My father thinks it's a battery issue. When I hit the starter button itll run for a second then cut all electronics and everything will restart. It'll do this until I'm able to start it. I'll try the gas tank trick though.
Great looking bike you've got there! Nice mods, headers & pipe look great. I got mine back in October and last week installed the evotech fender eliminator - what a difference! I can stare at it for an hour! My last two street bikes were an 03' and then a '13 Yamaha FZ1 and they were fantastic, do-it-all bikes, but this 1100 EVO is hands down the FUNNEST bike I've ever had - and my first Ducati. Love it.
Other than looks, whats your opinion of the clutch slave you installed?
Discussion Starter · #10 ·
Nice! Agreed, the bike is a major hoot. One of my all-time favorite bikes owned (out of 52 now), and next to my current Multistrada probably one of my favorite Ducs (out of 9 owned). That fender eliminator is nice, just cleans it up. Evotech makes good stuff.
The Oberon slave is one of those must-haves. First up, unlike the stock clutch slave, the breather hole is at the bottom (as opposed to the breather hole facing the countershaft sprocket on the stock one and sucking in all of that grit). Also the clutch pull is butter - they say a good 30% or so, but I swear it's closer to 40-45% less pull for me at the lever with this particular slave. It's that noticeable. I put a new line on it when I swapped it out, 30k miles was pretty good on that stock line. Plus the red makes it at LEAST +0.00002 HP. What mods do you have planned next? I think next up I'm going to do rearsets (Ducabike Pilot) and some more carbon fiber.
Next mods for me are, the clutch slave, and trying the 14 T countershaft sprocket. The sprocket, I already have - just need to install. When i was picking up my bike at the dealer, one of the service guys was standing there and mentioned to me that swapping the clutch slave was something that I should consider. So, for the relatively low cost for one, it seems they offer big gains in return. After that, I will get the ECU reflashed for sure, and probably some sort of exhaust change. I kind of like the dual muffler look, but it seems, in pictures anyway, the Termi's look almost as big and long as the stock set-up. What I really like are the Termi cans for the 1200. Those look really great - shorter length, a little more 'modern' looking...there would just have to be some kind of modification to make them bolt up to the 1100 - if its even possible. We'll see.
Discussion Starter · #14 ·
she's a beaut.! Where did you get the colored clutch line?
Thanks. The line is from Spiegler, you can order a specific color line any a colored banjo fitting (I went with red line with gold fittings).
  • Like
Reactions: raebears1100evo
Rizoma zero turns should be installed this weekend and need to order longer rear brake line to finish my rear set swap. Couple of carbon parts(chain guard and heel guards). Then maybe a 14 tooth front.
Great build on your part. Look forward to seeing more!!!
It makes a huge difference!
2013 1100 EVO ANNIVERSARY
** it's been over a year, finally got my account restored after that big change and I lost access. Recent mods include New Rage Cycles integrated tail, replacing my Ducati Monster Tailchop one (super nice, love it and so much more room for activities!), Rizoma Next tanks replacing those fugly pisscups, turn signals, CNC Racing flange, Oberon clutch slave with a fancy new red cable (hawt!, at LEAST +0.002 hp added), ASV levers along with some carbon fiber goodness. Next up for the winter includes a ** ton of stuff from Ducabike (Pilot rearsets, that nifty handlebar switch that looks like a MotoGP bike, and a damper, oil bath cover with new pressure plate, etc.), more carbon fiber, and some new wheels (gold Oz Racing Gass-RS more than likely). Any plans for winter mods on your beasts?
I own # 136 OUT OF 200. I see that you have added the "bikini" fairing to your bike.
I am in the process of also adding the fairing but am having a hell of a time installing it....did you find instructions somewhere? I can't find anything anywhere...
1 - 18 of 18 Posts
