Ronski, six days and NotaDouche still didn’t bother to tell you what he found after you helped him. Still think he’s Not a Douche ?
Douche96cr, what is your problem? Some other guy posts about his
salvaged monster, says nothing about whether or not he did any of the things on your checklist, and you're nothing but helpful suggestions. Here, I have to jump through your hoops and you give me nothing but grief? Don't think so?
Check the link. I joined in to give a pointer, too and guess what? No response. Do I care? No. I just hope it helped him and left it at that. Know what I else? I added info on a years-old thread that hadn't been updated
just to input what I thought was useful, usable information even if it wouldn't help me and the OP probably wouldn't be around to say 'thanks'. So again, please leave me alone, because some of us
haven't had the time to do everything on my own checklist, while before that HAD been replying with updates. And hey, I had asked a question that wasn't answered, so figured he had left it at that, too.
Again, no big deal. But if you're still so burned up by people not updating, just go back to that other dude and harass him for an update instead of me.
Ronski,
I appreciate the update on your airbleeds, that does help. Another half turn closer to my setting, the less crazy my settings are.
As you said, I am working things through for myself, because that's the best way to learn and figure out nuances to a new machine (not to mention less costly -- at least in the short term). To that end, I avoided buying an expensive leadown kit and made one, including adapters from an old spark plug, and verified that compression was top-notch. I'm now in the process of hand-building a manometer (and 5mm/0.8 adapters) so that I can tune the TB balancer, but haven't yet finished, so haven't gotten at the linkage, though I see it from outside.
My understanding from memory is that after checking belt tension and warming up the bike, I take the airbox, etc off, hook up the manometer, I close up the bleeders, start up again, balance vacuum at a forced 1250 idle, then adjust the bleeders in parallel to get a proper 1250 idle, then go back to the balancer, back and forth until everything is smooth. There was mention about setting trim and I think zeroing the idle stop or something, but I don't remember seeing a full conclusion to that thread. In any case, mine does not have a trim screw and the sensor has no adjustment (it has no rotation allowance). Of course, if all of this has to be repeated after doing a valve service, I should just go ahead and do the valve service first, though it should be easy enough to balance first and seems to be a good data point besides.
As for the air temp sensor: I couldn't find a reference for what the readings on the temp sensor should be and in any case, the digital gauge on the cluster appears to be working fine, as does the data coming off jpdiag, though that indicates 'water temperature'.
I'll report more incrementally if you like, but I'd sooner do a bunch of things more conclusively that would make for less scrolling through useless chatter for future owners. /Cheers
