I want to get a more aggressive look on my bike, anybody know where I can get smaller guages? :-\
Spend $700 and replace your ECU with an FIM U59. Then you can run any gauges you want.elmercurrie said:OK, great information, now how do I remove/bypass the immobilizer?
and does it really cost $700?elmercurrie said:Where did you purchase your FIM U59?
well it lists for $725 from FIMDavesax36 said:and does it really cost $700?
I think that's $725AU (FIM is from downunder) so that's "only" about $550US...Industrial_Grrrl said:well it lists for $725 from FIM
except it was listed "USD$725". Check for yourself. Wishful thinking it's $550DrunkenMonkey said:I think that's $725AU (FIM is from downunder) so that's "only" about $550US...
Beat me by a minute, I just went to double check and you're right!Industrial_Grrrl said:except it was listed "USD$725". Check for yourself. Wishful thinking it's $550
http://www.fuelinmoto.com.au/
I believe it's possible, but I won't be attempting it until January. I'm rebuilding a customer's 2003 Monster that was wrecked and the stock gauge cluster was badly damaged...BUT, the bike still ran (so the immobilizer worked). I'm going to try and fish out the circuitry involved, and seal it up in it's own little box and stuff it under the tank.Next question, has anybody tried separating the immobilizer electronics inside the gauge cluster from the gauge/dash cluster and tucking them away somewhere? Is it possible?
