Pulled the engine today out of my 1996 900. After, I found the short battery ground laying loose on the table. Can someone take a look and let me know exactly where it was mounted to the frame? I think it may have been on the back left bolt of the battery box/air box, but not really sure.
Jeff
I think you're right, but you can bolt it to any convenient frame mount. Upgrading the gauge of that wire is a good idea.
on my 95. the negative is mounted underneath the left bolt by the battery in the tray. it's a 5mm bolt that sticks out. on the other side you slide the grounds on and fasten them with a 10mm headed nut.
on the left side if you tray looks like this. if you need an actual pic, i can get you one.
Thanks much. I ended up finding the nut that dropped off the bottom, and then figured as much.
Jeff
