Nice!AKmnstr said:I made a fully adjustable piston stop myself out of an old spark plug. Here is how it is done. First the fun part. Smash the ceramic part of the plug. Then drill out the core of the plug with a standard size bit. Next tap the bore of the new hole and screw in the appropriate size bolt. You can now adjust the depth of the stop by turning the bolt in or out. This little tool works slick as snot and doesn't cost a thing if you have the proper ingredients in your shop.![]()
No, there's no spark plug long enough to do that.Ash said:is there an automotive sparkplug that is long that i can use as a piston stop? i'd cut off the electrode obviously. i figure this has to be cheaper than buying an actual piston stop... maybe.
This worked well for me. Just be sure to get a small rubber boot or something to protect the piston. You wouldn't want to ding up the pistons dialing in the cams. Don't ask how I know this one...AKmnstr said:I made a fully adjustable piston stop myself out of an old spark plug. Here is how it is done. First the fun part. Smash the ceramic part of the plug. Then drill out the core of the plug with a standard size bit. Next tap the bore of the new hole and screw in the appropriate size bolt. You can now adjust the depth of the stop by turning the bolt in or out. This little tool works slick as snot and doesn't cost a thing if you have the proper ingredients in your shop.![]()
That is one cool idea!!! If you aren't cranking the engine fast you won't damage the piston top --- just come up slow & easy. You could also round off the end of the bolt with a bench grinder too.AKmnstr said:I made a fully adjustable piston stop myself out of an old spark plug. Here is how it is done. First the fun part. Smash the ceramic part of the plug. Then drill out the core of the plug with a standard size bit. Next tap the bore of the new hole and screw in the appropriate size bolt. You can now adjust the depth of the stop by turning the bolt in or out. This little tool works slick as snot and doesn't cost a thing if you have the proper ingredients in your shop.![]()
