I'm expecting in the high 130's
Here is a run prior to the HC pistons and lightening work. Flowed heads, SPS cams, 50mm flull Termi system, DP ECU and an open airbox. It is contrasted on the same dyno with the bike in stock trim
Meanwhile, the custom dash also changed the LED backlight to white.
