I am reassembling the rearsets on my '00 M900s.
On the gear shifter, I cannot torque the pivot bolt to the 24Nm spec because there is too much friction and the pedal down not want to travel.
Is there a trick to reassembly? Do I just use locktite and tighten by feel?
I assembled with the following sequence, starting from the outside of the bike:
Bolt -> O-ring -> Pedal -> O-ring -> washer -> Rearset
Is this correct? Are the o-rings causing "pinching" -- should have have them elsewhere?
Thanks,
Tigre
You've got the assembly order/position right. Just check to make sure the o-rings aren't falling out of their 'grooves' when you try to reassemble.
May be that your washer is cupped a little, try flipping it over.
Thanks -- so I *should* be able to get it to the proper torque spec then, huh?
Tigre
Yeah, that, and it should pivot freely too... ;D
