Rode yesterday to get new tires on my 2oo6 S2R 1000. Had trouble with the gear shifting not returning to the appropriate position. It was "stuck" for a bit and then fell down onto my boot. Unpredictable. At home I check the linkage which seems fine. Running CRGs.
Is there anything within the shifting mechanism which needs lube? Any suggestions?
Thanks.
greg
I had a similar problem on my M1100. Long story short, the dealer pulled apart the clutch and found a loose bolt. once it was put back together it works fine. It is possible that in the years your bike has been on the road, something worked itself loose.
