1 - 12 of 12 Posts
What grade of gasoline are you people using for your Monsters and what is your experience with it. Any + or -. ???
· Registered
I run the base-bommer fuel in my 01' m750. I'm not sure if the reason is limited to the carb'd bikes. But there is talk of higher octaine fules fouling plugs and such. I was having that problem a while back, but it was PROBABLY due to other things wrong with the bike. I changed to the lame fuel fo ra quick fix, and I have not gone back. I haven't noticed any ill effects of running 87 yet.
Do a search on the forum for this, you should find lots of info about it.
· Registered
and CONGRATS on getting your bike.....this is the first we've heard of it right?!
where are the pICS..I KNOW you took some when you picked it up...come on..don't be shy. ;D
· Premium Member
I wish I could remember who made the post, but there was a pretty good explanation of why you only need to run 87 by somebody on the DML email list about 1 1/2 years ago. Anyway, since reading that, I've run 87 exclusively, track days and all, an my bike runs fine and I actually get a little bit better mileage.
I have an i.e. fwiw...
Mark
Discussion Starter · #11 ·
If you search this board for "octane" you'll get the big low down. Long story short, unless you have high comps, cams, altered timing, or a problem you can run 87 just fine. Using 91 will actually promote carbon buildup.
I used it for most of the time (once I saw the light) I owned my 33k mile 900 and never had a problem.
Discussion Starter · #12 ·
Thanx for all the replies...
however it seems like the opinions split in half...87 and 91
Guess I will start from 89 right in the middle and see how it works out...
Thanx again.
1 - 12 of 12 Posts
