How lean are the stock machines, for example, AFR at 14.1?
What fuel mgt systems are available that you can modify the maps without using hardware modules, like the PCIII or PCV or any other variants? Would want a software only product that can be used simply with a lap top. why? really don;t believe you need more hardware to remap and add more complexity (like another point of failure).
I'll do more searching on forums, but in the meantime....
Check out the "official closed loop" thread.
I've been in contact with Pro Tune in Italy and they have the only system to remap the new Siemens ecu - without having to add a module or remove the O2 sensors. It just plugs in to the data port under the seat of the new bikes.
Mine is going to be shipped out in the next few days, so I'll report when it arrives
