1 - 11 of 11 Posts
I have an 03 monster 620 dark, only owner 9k miles.  Its been in the shop for a month because 1 cylinder has been mysteriously dropping out randomly.  They finally diagnosed that it was the injector and it needs to be replaced.
Two questions:
1. Is this a problem any of you have run into?
2. Anyone know the tech specs for the injector so i can buy a cheap aftermarket? Or know where i can purchase a cheap 1?
[edit]I used the search and didn't find anything related[edit]
1. I don't recall anyone having an injector go bad.
2. No idea on specs or where to get a cheap one.
[edit]I used the searchde and didn't find anything related[edit]
Luck to you. I have looked for aftermarket units to no avail. The stock ones from Ducati are just about $520 :eek:
yea i know, and Ducati's website doesnt give specs on the injector. if i find out the specs will post and post the after market i get.
Had an injector go bad earlier this year, at about 13,000 miles. The problem was a really vexing one and it took a bit of time to diagnose (we originally thought it was the FIM ECU going bad). The injector ended up being rebuilt rather than replaced; cheaper than new, but still a pricey proposition. If you have a good mechanic locally, this might be another viable option.
Thats why I have bought several sets of throttle bodies on ebay, Its nice to have the spares.
Discussion Starter · #9 ·
they also thought it was an ECU issue during diagnosis. i will ask if they can rebuild it. how much did your rebuild cost? thanks for your response.
brad black said:
webcon in the uk. you need to know what yours is tho. it's probably a iwp043.
ty i will definately check them out
california cyclworks told me to ask you if you had any used injectors :)
so got any for sale?
The rebuild cost was $100, but the initial trouble shooting added about $85 (time spent on dyno, rechecking the ECU map, etc.)
Good luck, hope your injector problem gets resolved!
1 - 11 of 11 Posts
