It looks like I can finally get my bike out from under the garage now that the ice on the ramp has mostly cleared off.
I went to start her up and not only did she refuse to start up, but the throttle grip was frozen shut! I tried to help her start with a little gas, but I couldn't even twist the grip. She has been sitting there in the open albeit covered garage at an average of about 20 degrees of coldness since wednesday.
I didn't think throttles froze shut. How should I get this unstuck?
Also, any tips for helping her start out again? It's cranking pretty rough and very slowly.
UPDATE: I went back out and simply worked the throttle loose by hand. As for starting her up, I'm guessing the battery is dead. All batteries perform worse in the cold, right?
So, your throttle works now, right? You may want to try using a heat gun/blow dryer over the cable housing before riding, and try to wait until the air temp is a little over freezing.
Does it turn over? If it'll still turn over, you might be able to get it to catch with a little squirt of starting fluid. If it's starting to turn slower, than don't keep hitting it without either a) letting the air temp come up to ~40+, b) squirting in a little starting fluid, or c) hooking it up to some jumper cables. If you jump it with a car, turn the car off, hook up the batteries and start the bike. Disconnect, let the bike warm up a little, and plug it into a tender when you get home. (Keep the car off the whole time)
Good luck.
Yeah the throttle works now, I just needed to coax it loose by twisting it harder.
The main thing I was afraid of is if there was some liquid in there that wasn't supposed to be there because freezing sometimes means cracking, and cracking is bad.
I went back home and brought my battery tender to work. I just put the battery back in, and the bike started right up, seems to be running better than ever.
