I took both the front & rear wheels off recently to change tyres, now I have a funny sort of whistling noise comming from the front end.
The Duc genuine manual is fairly Vague. I assume the front axle nut is refered to in the catalogue as the Axle pin & is meant to have 65-70 nm torque????
I'm talking about the M14 Hex head shaft that goes through to hold the front wheel from the brake lever side.
If I tighten it up more than just a nip, it restricts the free wheeling of the front wheel. If i gave it a 14 turn after it's seated I don't think i could turn the wheel at all.
This may be a stupid question, but this is my first wheel removal on any motorbike, so go easy please guys!
Have I got something A$$ about face??
PS: Also a Learn't not to loosen the locking screws on the clutch side of the axle shaft when removing otherwise you will shear off your speedo drive, Buggar, I have a new one comming!! Maybe this is causing the problem.
It's been like this for a few weeks, but I just read something in one of the other threads that makes me wonder if all is OK?
