750 mnster with pods and keihins is the bike.the problem was gradual until finally at my sisters house only the vertical is firing.ok check all connections specifically involving the ignition system.no luck..switch around the coils and connections appropriately.no luck.switched around the ignition control units still no luck.only the rear cylinder firing only.pull out the multimeter and check the resistance on the red,white wires that control the front cylinder firing and there was no reading at all..checked the yellow,black wire that controls the rear cylinder firing and it read 105 ohms.so obviously it tells me that no signal is being set from the motor to the control unit.so my question is,am i going the right direction in diagnosing the problem?the red white wires specifically the white has some insulation worn exposing the wire underneath.should i go further down the red,white wiring leading the the motor,expose some wiring and do another multimeter reading?or is it "have a cup of courage" and remove the left hand crankcase cover and do a pick-up coil air gap check and check the wiring inside? thanks all as this bike is my main transportation and all work has been done by me except for suspension.hopefully i won't have to replace the pickup coil as setting the timing could be ugly...lat.
