Okay, this question is for my ST2, but I know the Monsters have the same brake switch setup.
The switch to cause the front brake to turn on the brake light closes the circuit when you pull on the front brake. There is a tiny switch that bolts to the brake lever mounting bracket with tiny screws, with a button about 1mm in diameter that opens the circuit when it is depressed about half a millimeter. When the brake lever is released, it presses the button.
The question is: what is between the brake lever and that switch?
I'm guessing that it is a round ball bearing or something, but I ended up carving a little cylinder out of wood to fix my brake light. If it's a ball bearing, anybody know where I can get one the right size?
I would like to find out who at Ducati invented such a system where it's so easy to lose the part. You probably have to buy a whole brake assembly to get the replacement too.
