I want a spare set to mount up my track day tires. Prefer black in color with brake rotors and maybe the cush drive. 2001 M750
Thanks!
[email protected]
Todd Puckett
Thanks!
[email protected]
Todd Puckett
The rear is 4.5 or 5.50 wide? According to posts in "Accessories and Mods," if I change up to 5.5 I will have issues with sprocket alignment as the hub is wider. (?)funonone said:You can have the black rear wheel with sprocket carrier, and disc rotor fo $99+ whatever shipping is going to cost.
Luckyontheducky said:The rear is 4.5 or 5.50 wide? According to posts in "Accessories and Mods," if I change up to 5.5 I will have issues with sprocket alignment as the hub is wider. (?)
So Ducman, If I get a 5.50 wheel and the sprocket hub that came with it I will be ok? Will I need to do anything with the front sprocket?ducman851 said:Yes, youwill need the correct sprocket holder.
Cool. Any dents/scratches? How much for rear wheel/brake disc/sprocket hub cush drive combo? Also, what is your location (for shipping costs)funonone said:The black wheel I have for you is a 4.5. I measured a 5.5 and a 4.5 wheel w/ hub assembly mounted , inside of disc rotor to inside of sprocket on installed bikes and they both measure 170cm. Maybe there are different carriers but I don't see it?
Yes, the front should be fine.Luckyontheducky said:So Ducman, If I get a 5.50 wheel and the sprocket hub that came with it I will be ok? Will I need to do anything with the front sprocket?
