I didnt want to pay $40 bucks for a sidestand bypass so I did some experimenting and made one myself for free.
On my 02 M620 (yours may be different) the kickstand switch is nothing more than a SPST switch that is open when the stand is down and closed when the stand is up. Simple enough. If you follow the wire going from the stand up into the frame, you will come across a plug where the wire simply links with another wire. (its almost like Ducati knew everyone would be bypassing this and added this to make it easier) Unplug this plug and take a look at the upper half of it. You will notice that there are 2 wires running into it and 2 terminals in it. There are some dummy terminals there too, but we are only worried about the real ones right now. Basically what you do is short these 2 terminals. I used a thin gauge paper clip stolen from my office. (you could use a small gauge wire 22-24AWG, but I wanted to keep it free) Now you have a paperclip keeping your bike running, so I would only recommend using this to warm up your bike unless you secure it somehow (electrical tape maybe?).
