I'd be interested in swingarm sliders. What was invoved in that add on, and where did you get them?
I assume the M1000S comes standard with swingarm spools? If so, you should be able to use the Lockhart-Phillips swingarm sliders and just thread them in place of your OEM spools. They don't list a set for Ducati, but I believe the Yamaha sliders use the same bolt thread.
(Check me on that one... I know the Suzuki sliders use a larger bolt as I had a larger than stock bung welded into my steel swingarm so I could use the larger bolt, assuming that it'd be stronger in case of a crash... Knock wood)
--Fillmore
You switched to high pipes, right? After some embarrassing parking lot antics, I've realized the Monster already comes with frame sliders- big, aluminum, oval ones.Have any of you w/ frame sliders considered adding swingarm sliders?
