·I have a pair of Showa non adjustable forks, that I believe the
damper tubes went south on me....they are just sitting around, but they do have .95 racetech springs and gold valves in them, and the tubes themselves are good....anyone have a need for them?
They never got together again once Manley Cycle pulled them apart and could not get the damper tubes to work right, but I figured someone may need a good set of tubes, springs, and gold valves. Would prefer to just send the lot to someone if they have a need, no idea if they are worth anything, and I am prolly missing some shims somewhere, and other little bits, but I may be able to find everything. But the tubes, valves, and springs are good. 65mm spacing on the calipers from a 2000 M900. Let me know if anyone could use them.
