I just acquired my first Ducati, a 1988 M900. It was leaking from the fork seal. i cleaned it up and it isn’t leaking anymore but it lost a significant amount of fluid.
is there a way to replace some of the fluid without disassembling the entire fork?
You didn’t replace the seal but “cleaned it up and now it’s not leaking anymore “ Do you mean cleaned the seal with a SealMate or do you mean wiped the oil off and there isn’t any more oil in the fork oil to leak ?
