1 - 9 of 9 Posts
SO I have been riding in the cold damp weather alot lately and last night when I got home, I noticed something funky.
I don't have a pic of it, but the oil level siteglass looks like a mog of frosty cold root beer. There is a thin line of oil at the bottom and then a creamy tan foam all the way up to the top of the siteglass.
I just recently did an oil change(less than 100 miles with 15-50 Mobil 1 Synthetic) and changed the plugs. I pulled the fill plug and there was some foam in the recessed portion of the plug. I smelled it and it smelled like normal warm oil smell with no hints of fuel or water. I also shined a light down into the engine and saw the oil sitting in the sump and it looked normal.
I looked at it again this morning and it was still sitting with the same thing.
I rode it to work this morning and had no strange noises like there were internal problems. And it ran fine.
Any idea? I wouldn't think running an open airbox lid would create issues with water being sucked into the engine, but then the only thing I have ever seen relatively close to looking like this is the last time I had to do a head gasket on a car and water got into the oil.
Any help would be greatly appreciated. I don't want to harm the engine and I am going to change the oil again this weekend to make sure I don't. But I don't want to have to do this every weekend.
Thanks.
Ryan
Sounds like the typical 'oil not getting hot enough for long enough' deal. I cover the oil cooler this time of year and have no problems with either too hot, or moisture in the oil.
I have had this happen as well before my last oil change. I figured it was moisture in the oil.
What do you use to cover the oil cooler?
anybody have a vague idea of how cold is "cold enough," when it comes to wanting to cover up your oil cooler?
i rode across town this morning and it was about 43 degrees, but the bike seemed to warm up and run fine.
Duct Tape. 43 deg is cold enough unless you're riding a fair distance.
To the OP if you cover your cooler and ride the bike for about an hour the moisture will disappear. No need to dump that oil.
Discussion Starter · #9 ·
Thanks Nate. And everyone else with input.
I covered the cooler this morning with several think layers of foil and put my Rizoma oil cooler guard back on over it to hold it in place.
I took a short ride and when I got to work this morning, looks like it has pretty much cleared up. I always forget that cool air good for engine while cool oil can be bad since it can't 'burn off' contaminants properly.
All seems well and I really am glad since I place on doing a few hundred miles this weekend.
Thanks again guys,
RYan
1 - 9 of 9 Posts
