hi all. i have a 2009 696 it's been sitting for a little while and im trying to get it going again.
I've had it all apart, testing everything and the last thing i can think of is a bad ECU...
So i confirmed spark, confirmed fuel pump is priming, there is pressure at the rail/injectors. noid light showed no flash. took injectors off, had them flow tested. tested fine...
New battery. while cranking over will fire with starting fluid and idle AND CONTINUE TO IDLE if you continue to shoot some starting fluid in it (which i know is not good for the cylinders, but for testing w/e).
i checked all the wiring for the injectors, all looked fine. This is how ive come to believe it is the ecu itself. Any other input or things to check ?
Appreciate any and all help
