Is that a cirrusblau E24?!?!?
Love it! [thumbsup]
MTX??
Love it! [thumbsup]
MTX??
It will get worse, I'll tell you. Mine is a mess and I haven't found any normal cleaners which will remove it. I'm not trying acetone since I'm sure there's something better out there which won't do any damage. Mine at least seems to have stabilized and isn't any worse now. But, it's not very nice at all. Of course, I do ride a lot and the engine sees a lot of road debris. Most of that comes off, though, with my weekly wash. I wonder if anyone out there has worked out a safe way to get this stuff off?BK_856er said:The rubber pucks don't seem to be melting, but apparently some adhesive OR some coating to aid installation does degrade when heated. Maybe someone invented a new trick on the assembly line, or they made a substitution. Or maybe the 695 just runs hotter than other monsters (>300F yesterday) due to the lean mixture and lack of an oil cooler. I'll be sure to point it out to the dealer, but should I expect them to "fix" this type of cosmetic issue? I think I can live with it unless it gets worse.
BK
Same here. I was typically seeing as high as 265 but that was it. Now around 1k miles Im seeing a max of 250 normally around 215. However, the weather is getting colder so that might have something to do with it.nllm_oo_mlln said:>300 degrees?!?!?
i think heat is the culprit and since oil starts to break down at around 280ish I think you ought to change your oil. The highest I have been was 284-- but it was running no less than 265 durring this period. since it's been broken in and had a few oil changes its running between 210 and 250, and I'm not getting any new ooze.
I think your oil is shot though. not sure how close you are to 600 mi but it might be a good idea to go in a tad early
Although so-called high temps aren't 'out of the norm' as you say (display will read HI when its too hot), Ducati does offer an oil cooler for the bike. You might consider that as your first mod, if so inclined.BK_856er said:OK - good to know high temps on the M695 are not out of the norm. I'm hoping that my numbers come down after I get a few miles on her.
I was checking out the bike today and I got to wondering why the lower exhaust pipe is severely tarnished for a good 12 inches, whereas the upper exhaust pipe has retained its orginial finish along its entire length. Only 50 miles on the odo. Lean mixture and excessive EGT temps in just one cylinder perhaps? Why else would only one pipe get discolored so quickly??
I have a portable wide-band O2 sensor and a digital thermocouple. I think I'm going to collect some data on this issue.
BK
BK
I'm no expert, but that doesn't sound kosher...he's suggesting that the cylinders are fed fuel/air in 'ever so slightly' different amounts? How does the cooling air flow affect a/f ratio...can someone help?spankee said:he said that in fact it was set up that way on purpose. the front (horizontal) cylinder will run ever so slightly hotter (leaner) because it gets all the airflow to cool it. the rear (vertical) cylinder runs cooler(richer) because it is hidden away and is less exposed to air flow.
I've got 7800 miles on my M695 and I've got a lot of gunk on my heads from cooling puck residue. It's not getting any worse so I assume that means the goo has all oozed out. My headers are quite dark brown and a little rusty too. I'm having them ceramic coated inside/out this winter to a matte black color. This lets them run cooler, protects the pipes from corrosion, and allows air in/out faster which can marginally improve performance too. The front header is more exposed to the road and therefore more debris, dirt, water, etc. So, expect the front header to discolor faster. Coating might be a good option if you're concerned. I am for looks and to cool it down. I'm also installing an oil cooler.BK_856er said:This pic shows the "blueing" and "tarnishing" of the lower pipe at 30 miles on the odo. I'm cool with it, but I found it odd that the other pipe is not yet discolored. Got me to wondering if the 300F oil temp and brown goo from the cooling fin pucks could be due to high head temp in just one cylinder.
BK
