Yes you can, there are 3 options
1.PCIII
2. Techlusion box
3. FIM 5.9 Replacement ECU
Its a fairly complex piece of electronics (the 5.9) The security thatencompasses the map is pretty good. Duane at FIM worked on cracking it for the longest time, but ended up making his own unit which actually does some pretty cool stuff.
Disables the Immobiliser function for all models. You can use the U59 on a race or track bike without the ignition key, immobiliser aerial, and immobiliser unit.
Supplied pre-mapped for most applications - slipon mufflers, revised cam timing, etc.
Fully mappable for Fuel Map, Rear cylinder Correction Map, Spark Map, and Rev Limiter using a new version of our Mapper program (available to dealers)
Can be operated in Road Mode (all side-stand cutouts, starter button, clutch switch etc. functional) or Track Mode (Kill Switch only) so you don't need to wreck your wiring harness to go to the track.
Each cutout function can also be individually set if you wish.
The Dashboard Water Lamp or ECU check lamp can be used as a Programmable Shift Light in addition to the warning function.(Some models only)
Can be diagnosed using the Ducati Mathesis Tester or our UltiMap Diagnostics Software.
