Did my tail chop last week...99 M750..
the 99 M750 has the rear signals integrated with the plastic flap (so you cant just ditch the mud guard)
I ordered the signal relocator from Motowheels...came fast- works great.
link to signal relocator:
http://www.motowheels.com/italian/m...rFor=&collection=168|Italian Motorcycle Parts
Unbolted my mud flap, pulled the wiring out and the plate off...
Then took a cutoff wheel to my frame ;D then reversed the lock cable direction so the lock cable then ran under my seat in an "S" shape so that it would meet back up with the lock mechanizm from the original direction (the seat-lock works perfectly still)
then put the signal relocator on and mounted and wired my signals....
then took two pieces of aluminum strap about 5-6" long and bent them to around 110 degrees? Drilled them out, and bolted them underneath with the existing bolts and bolted my license plate on....DONE!...
took me all of 1 hour....
I LOVE it and am so glad I finally did it. 8)
