1 - 14 of 14 Posts
I finally got the bike to start, turns out it was the starter and I had it rebuilt for $40 I let Ducati of Oceanside pull and reinstall the starter and it cost me $130 so everything worked out good.
Now onto the next challenge, The bike feels like it is not getting enough fuel from idle to about 3000rpm The Mechanic at Duc and I talked about it and after a compression test we are pretty sure its a carburation issue. I have FCRs not sure which ones cause they were on the bike when I bought it. The bike is a 94 M900 with the 944 kit. Once you get the rpms up it screams and it runs fine if you give it alot of gas off idle. I just dont want to do wheelies at every light :) I changed the little inline fuel filter which had some visible crap in it (it is an aftermarket clear filter) The mechanic said he didnt think it was a jetting thing and we tried to adjust for it but no luck. He said that the fuel pump is vacuum/rpm driven and with these carbs maybe it is not giving enough fuel at the lower rpms. Any ideas?
Oh, the guys at Aprilia Ducati of Oceanside are awesome! They got right on my bike and even let me in the back to try and help figure out whats up with the carbs. Great guys, great shop.
There's a thread here somewhere from a guy that found a fuel pump rebuild kit, just search for 'fuel pump' and you should find it.
Your Monster is old enough that the fuel pump may be getting weak.
Chris Kelley at:
http://www.ca-cycleworks.com/
Sells FCR kits, and is very knowledgable on how they need to be set up.
IMHO, it sounds like either the idle mixture adjustment is off, or your idle jets may be gummed up. The jets can get gummed up if the bike has sat for a long period of time.
Yep, gummed up idle jets was one of the common theories. I have no idea if the bike has been sitting or what since I just bought it. We did try adjusting the idle mixture with no luck.
I dont have any info on these carbs to give me help with breakdown and cleaning. Does anyone know where I can get a breakdown diagram or simple instructions?
Nothing on the Sudco site?
Just did a search and found the sudco site. They have a decent diagram. Im guessing that its the main and slow jets that I should try and clean out. Im not really sure if I am ready to break these carbs down without a manual but I guess I gotta learn someday. I just got my service manual in but it wont exactly help me with FCRs ???
Thank you very much!
Hey Chris, If you read this (I tried to send you an Email but it was blocked due to too much spam) I want to thank you for all the usefull info.
I just located a fuel pump for $118 so I figure Ill try that, a new fuel pump cant hurt anyway.
NO don't get that $118 fuel pump!!! I got your e-mail, that nasty gram is there to "bounce back" to the spammers so they'll eventually get me off their list. I likely won't deactivate the e-mail account for a while...
There are a few options. If you search on this site, someone posted a link on how to obtain fual pump rebuild kit. Otherwise, I can sell you compatible vacuum pump for 1/3 the price of Ducati.
:) Chris
Discussion Starter · #11 ·
I went to another shop and had a tech ride the bike and this guy said he thought it was carburated fine and that it felt like clutch problems to him. I started taking the clutch apart and I will start a new post about my adventures there.
Finally got around to calling Manufacturer's Supply. $11.50 and a new fuel pump kit is on it's way. They said that they're getting quite a few requests for that kit. Go figure...
1 - 14 of 14 Posts
